sprocket
The DA I've been working on is hard to start if it sits for more than an hour. I think it is running rich on start-up, or maybe there is fuel that leaks from an injector that it has to burn off on the next start-up. That might even explain the misfire if there is a faulty injector. I'm not getting a misfire code now, but I think it still occasionally misfires.
So tomorrow I will check the fuel pressure and see if it holds pressure after shutting it off. I'm not quite sure how to proceed if it doesn't hold pressure. My friend Tim thinks it might be the FPR, but I'm guessing it isn't. I suppose it could be the fuel filter and I don't when, if ever, it was changed, but I think it's rich on start-up, not lean.
If the evidence points towards an injector problem should I try running something like Redline or Techron through it? Maybe another Seafoam treatment? I do have a full set of spare injectors, but how can I identify the bad ones? Stethoscope?
Thanks for any advice. I know I ask a lot of questions and I really appreciate the help and appreciate this forum. Thanks!
