2005 Lincoln LS V8
Hi, it's been a while since my last post.
Has anyone attempted to remove and replace this valve?
If so, did you get to it from the bottom or top?
I can't even see it. I used AI to help diagnose and removed part of the coil cover on the driver's side.
Initially, I thought it was my degas bottle however, I replaced it a few years ago with everything else, Water Pump, Thermostat Housing, Hoses, DCC Valve, Hoses, Radiator etc...
It's clearly leaking right at the bottom of the Power Brake Booster onto an electrical connection. (Bad Design what were they thinking).
When searching online the DCC Valves keep showing up as this is totally different.
the Part Numbers AI came up with:
Thanks
- Motorcraft: YG‑436
- Ford OEM: 4W4Z‑18495‑AA
- Jaguar OEM: XR8‑2834 (direct interchange)
Thanks
