14.6@97MPH
Next problem with my car
I've got a 98 LSC. After the car is warm (15-20 minutes) my speedo starts jumping around. If I'm going 60, it bounces down to maybe 40 and jumps back and forth between the speed I'm going and 15-20 mph slower. Eventually, after this happens a couple of times, my ABS light comes on. If I'm driving slow while this is happening and the ABS light isn't on yet, when I touch the brake the abs will come on (even though I'm not sliding). I can hear it and feel it in the brake peddle. The tach runs normal and the odometer puts miles on based on the speedo (not the speed I'm actually going).
I replaced my ABS module a couple of months ago with a junked one (new are not available), and that seemed to work fine for a couple of thousand miles. When that broke I did not have the jumping speedo.
I've done a lot of searching on this problem and I can't find a good answer. Where exactly does the speedo on a 98 LSC get it's reading from (I found a lot of posts saying 'i think', 'it could be', 'maybe', etc.???) I have not had the ABS codes pulled yet. If I do have them pulled will it give me the right answer?
Thanks,
Ken
Thanks,
Ken
