Onefreshls
ok so what did you go to school for just batterys bc that is what it sounds like.
Does an OPTIMA battery ever gas?
When used with a properly regulated constant voltage charging system (such as an alternator) the OPTIMA will usually not emit hydrogen gas. However, gassing can occur when charging at higher voltage levels or in extreme high temperature conditions. In automotive applications this typically will not happen if the alternator/regulator stay below 15 volts.
What is a Gel Cell Battery? Is OPTIMA a gel battery?
A gel battery design is typically a modification of the standard lead-acid automotive or marine battery. A gelling agent is added to the electrolyte to reduce movement inside the battery case. Many gel batteries also use one way valves in place of open vents, which helps the normal internal gasses to recombine back into water in the battery, reducing gassing.
An OPTIMA battery is not a "gel" battery or regular flooded acid battery. An OPTIMA is a Spiralcell AGM battery.
AGM, or Absorbed Glass Mat Batteries
A newer type of sealed battery uses "Absorbed Glass Mats", or AGM between the plates. This is a very fine fiber Boron-Silicate glass mat. These type of batteries have all the advantages of gelled, but can take much more abuse.
Absorbed glass mat (AGM)
Absorbed glass mat (AGM) is a class of VRLA battery in which the electrolyte is held on the glass mat separator by way of capillary action.
when i said the thing about the d battery a optima battery has six round tubs smiler to a d shape battery.
Just vent the damn battery. I vented mine with about $10 in parts from a hardware store in the plumbing section:
http://www.lincolnvscadillac.com/showthread.php?t=48188&highlight=cheap
So does every car with a trunk battery have a vent system??
And a battery can explode at anytime.. I was in a vehicle with a battery that just decided to pop under the hood while parked. Never been overcharged and only a couple years old.
every car that ive ever worked on with a factory rear battery did, including the GM's with the battery under the rear seat.
lol @ strap it to the ABS
my old audi CS has the battery right under the rear passenger seat
