ive searched with no success
soundwaves454
L.A. County
ive been searching since my pillar got messed up in the attempted theft of my car. does anyone know how to remove the pillars from the door? i don't want to buy the stick on pillars and can't find any oem replacements. i want to bondo, sand and repaint. any help will be appreciated
alex
painting it to match may be difficult.
However you will need to roll the window down and take off the door panel inside. then remove the mirror.
Next on the out side you will see several small screws on the trim where the mirror is, remove those and pull up the bottom trim. Next you will remove the window seal from the top and all the screws and take off the top part off. Then i believe there are a couple screws on the back part you want to take off, remove those and it should pull right off.
I have all these parts unfortunately for the passenger side...
