i've been searching high and low...
Lownslowlsc
N il
were is the pic of the wire you need to cut to disable the air ride messege? i'm color blind so it makes it allitle harder. I've seen the pic but cant find it.
I think it's the green wire. Red one makes it go boom.
Read post 2 and 3:
http://www.lincolnvscadillac.com/showthread.php?t=31589
Mind, even that won't help if you can't tell different colored connectors apart... BRB :D
EDIT: The gray connector is the one furthest from you i.e. closest to the firewall.
EDIT again! :D
Here's a great pic from BlackIceLSC:
And a reminder for first timers: Don't break the kick panel trim!!! (don't yank it - it has a clip and must be slid back to remove i.e. you slide the trim towards the back of the car)
