Couple of days ago neighbor kid closed my trunk (didn't seem like he slammed it very hard) and the trunk lock cover snapped off from the panel. Looks like it was gonna happen anyway even if I were to hit a bump a little hard.
Nothing happened to the lens's. But also since I have never removed the tail lights before I don't know if the panel that broke is also part of the housing. I'm sure someone here knows.
I still got my 93 that I have been using parts from already. Time to remove again I guess.
BOTH panels I have are cracked right in that same area. They are flimsy and break easy if too much pressure is put against them. I reinforced mine with .040" T6 aluminum and have not had a problem since.
Happened to mine, that plastic is very brittle. It's the main reason when you see tail light panels for sale people think they are two pieces but they are truly one piece and that area always breaks, I reinforced my current one with jb weld before i put it on.
I work as an aircraft mechanic and I made a template of cardboard. Transferred the cardboard to the aluminum, trimmed and fit the aluminum, and then used A4-Metalset (much like JB-Weld) to glue it in. NO more problem.
I'm not gonna be able to get to fixing mine for a few months but I also don't plan to until I get a new emblem anyway. The panel on my 93 is still intact for now so when I do get to it I have to be careful not break it.
And then look into doing the same as markup7 with the aluminum. I like that idea.
