kaha
I love those wheels
Thirded. They really do look great on the car.
I love those wheels
you can put 2005 or later Mustang 9" rims on the rear with no issue, but you cannt put them on the front.
you can put 9" 05+ wheels on the front. many have done so.
Right, with spacers, correct?
I heard that stock 17x8 rims from 05+ hits the UCA in the front with the 45mm offset.
you have about 6.5" of backspace in the front of a mark VIII.
a 17x8 wheel with a 45mm backspacing gives you 6.3 inches of backspacing.
therefore, it fits. although it would be tight.
so it would seem you heard wrong.
a 17x9 with an offset of 24 mm (like my 04 cobra wheels) gives you 6" of backspace. so you have even more room to clear the spindle.
the ideal backspacing for a mark viii is 36mm. the closer to that, the better, a 36 mm will fit up to a 9 inch wheel in front.
a 40 mm offset will fit a 10 inch wheel in the back.
both of these are without fender cutting or rolling. possibly minor trimming.
Hi everyone.
My name is Alexey, I'm from Moscow, Russia.
Portofino Blue Mark is mineMy friends:
And welcome!
I sold an oil pan to a chap from Moscow a while back. Nice to see so many VIII's in one place over there.
Miha, you don't tell the others I bought the wheels!
They are now moving to me be sea freight.
Going to be a kind of surprise.
so i think i have made up my mind on which wheels im getting-
they are 18x9 30mm offset / 6.18" backspacing so i think i should be ok....?
Planning on doing all 4 wheels/tires the same so i can rotate.
Any chance of using 265x40x18 on all four corners? or no? should i stick to 255x40x18 on all 4?
I have seen someone on here run a 265 up front but they had a 25mm offset..
the 255 are 26" tall
the 265 are 26.3" tall
Also planning on lowering the car 1.25" - 1.5" on t-bird springs.
input?
input?
I think I would start a thread with that question because what you just asked can get complicated and get many responses in Lunar's thread.
