Interior / Exterior Light Breakdown
NoLimit95
Huntsville, Alabama, United States
I know it's somewhere in the webs but now I can't find it. I need to know the bulb numbers inside the Gen 1. I already know the ones for the front floor board and door panels because I have swapped those out for LED's. Just need to know what the two rears are and the ones above the head. Mine are right above the head, not at the front like my 94 had. The 94 had a moon roof but the 95 doesn't, so I guess that's the reason for the relocation.
I'm also going to put in LED's for the entire exterior. I'm going with 2-5 watt type. No junk from china. I have another rear light bar that I am going to work on installing LED light strips on the top half and bottom half and then it should appear to have the neon look and with them lasting anywhere from 60,000 to 100,000 hours, I should never have to worry about any of them going out for the life of the car.
Does anyone have the link I'm talking about or know all of them off the top of their head?
Location [Stock Bulb #]
Ash tray [161]
Automatic transmission indicator [168]
Back up light [3156]
Brake warning [37]
Check engine indicator [37]
Directional signal indicator [37]
Dome light [906]
Front sidemarker [194]
Front turn signal [3457A]
Glove box [194]
Hi-beam indicator [37]
High mount stop light [3357]
Instrument-general [168]
Instrument-general [37]
License plate [168]
Map light [168]
Map light [912]
Parking light [3457A]
Rear sidemarker [916]
Rear turn signal [3357]
Seat belt indicator [37]
Step/Courtesy light [168]
Step/Courtesy light [89]
Stop light [3357]
Tail light [168]
Tail light [3357]
Trunk/Cargo area [912]
Under hood light [912]
Did a quick search.
Thank you! I just found them at the same time you posted lol.
http://www.modifiedlife.com/1995-lincoln-mark-viii-car-light-bulb-socket-sizes/
Low Beam Headlight Bulb Size: 9005
High Beam Headlight Bulb Size: 9005 or 9005 HID Upgrade Kit
Parking Light Bulb Size: 3457A
Front Turn Signal Light Bulb Size: 3457A
Rear Turn Signal Light Bulb Size: 3357
Tail Light Bulb Size: 168 or 3357
Stop Light Bulb Size: 3357
High Mount Stop Light Bulb Size: 3157
Fog/Driving Light Bulb Size: H2
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 916
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168 or 912
Dome Light Bulb Size: 906
Step/Courtesy Light Bulb Size: 168 or 89
Trunk/Cargo Area Light Bulb Size: 912
Under Hood Light Bulb Size: 912
Instrument-General Light Bulb Size: 168 or 194 or 37
Check Engine Indicator Light Bulb Size: 37
Hi-Beam Indicator Light Bulb Size: 37
Seat Belt Indicator Light Bulb Size: 37
Brake Warning Light Bulb Size: 37
Automatic Transmission Indicator Light Bulb Size: 168
Directional Signal Indicator Light Bulb Size: 37
The brand I'm going with is Putco
http://www.putco.com/products.cfm?action=CategoryView&Id=2d6754bd-9be8-c408-ae66-fd8037d1078d
You can also try highperformancebulbs.com
Some of those look good too. In some places, I need the round style with about 7 to 9 SMD's and one on the top for areas like the rear side panel lights, tag light and I need to replace what I have under the dash because they seem to be shooting a beam down and I want them to spread down there. There are two above my head on each side that I do need a beam out of and then the one in the middle would need to be the bright one and rounded.
I'm wanting to mainly use anything 2 - 5 watts at 6000K. I already have the front corner lenses done in the amber section but now I need one with a beam to it that shines out at the curb when the blinker is turned on. I'm sure I'll need load resistors for anything that blinks or will be using the brake lights. I want the reverse lights to beam also and be around 5 watt. My door panels are taken care of already. I want the interior finished before I move on to the exterior. I'll probably have to get lights from a few different places to make sure I get what I really want.
Not that old of a thread but i want to make my reverse lights brighter on my 95. These are the back up lamps right? Can i find bright bulbs at autozone or pepboys in the needed size of 3156? Another question is what brand should i look for?
nvm noob question, ill get two backup/ reverse light led bulbs, size 3156 from autozone or something, its not that the reverse lights are dull- but LED's would look great.
I was thinking of these for my reverse lights but haven't messed with them yet. I have to make sure there is room for them but it looks like they would fit, length wise.
[url]http://www.ebay.com/itm/2pcs-3156-3157-CREE-5w-12-5050-SMD-White-LED-CAR-BACKUP-LIGHTS-w-PROJECTOR-LENS-/110867404374?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d0365656&vxp=mtr[/URL]
They look like they would, i'm probably an idiot, i bought sylvania superbright 3156 bulbs, completely forgot to ask for LED as i didn't see any there. oh well =/ i'll see how bright these are at night, if not i'll return the 2nd pack and buy some LED's off the internet.
Those are normal LED's and your sylvania super brights will probably be brighter than those. SMD LED CREE would really put out back there. I done my interior with all 194 SMD LED's. All of them are 5 SMD, except for the two in the rear side panels and they are 9 SMD LED's. Turned out to be pretty bright in there.
This pic is without the two map light switches turned on, so two of the lights aren't even on.
All light is coming from SMD's like this.
I just ordered a pair of LED's off amazon, hopefully they're bright or else i just threw more money down the toilet lol.
