Intake manifold modification
Lincoln Mark VIII Performance
  1. robsMarkVIII
    robsMarkVIII Active LVC Member
    56
    3
    Nov 25, 2014
    United States
    With the cost and low availability of the 96-98 Cobra intake has anyone thought about modifying our manifolds? From looking at all the different manifolds it looks like our manifold just lacks volume. This could be solved by changing the way air is admitted to the manifold. I have two 97-98 manifolds and I am going to modify one of them to increase airflow.
    Any thoughts on this?
  2. jbelcourt
    jbelcourt Dedicated LVC Member
    572
    23
    Nov 1, 2013
    Orlando
    Please share pictures as you go. I'm really curious.
  3. markup97
    markup97 Active LVC Member
    138
    8
    Dec 27, 2013
    St.Cloud
    Ok, I went the same thought direction myself. There is very LITTLE room for improving the 97-98 intakes. The plenum area is way too small and restricted at the base, and due to the upper intake 'Y' positioned as it is, it chokes the ability for runner porting. Believe me, after cutting a 97 intake apart, I tossed it in despair.
    I hate to say it, but either get the 96-98 Cobra intake or go C-head/intake swap.
  4. robsMarkVIII
    56
    3
    Nov 25, 2014
    United States
    I think you gave up to soon. I am going to get rid of the y and make an upper plenum. At the rear of the intake where the vacuum lines connect I will make another entry point for the lower plenum. The vacuum connectors can be placed on the new inlet. I will make a cardboard mock up soon, I will post pictures when I get to this point.
  5. markup97
    138
    8
    Dec 27, 2013
    St.Cloud
    So let me get this straight; you are basically going to Hybrid a Gen2-Gen1 intake? Use a rear-entrance throttle body type set-up and get rid of the 'Y'?
    At this point, just grab a pre-99 Lincoln Conti intake or use the 93-96 type with the later IMRCs.
    Ok, after re-reading your post, it sounds like you are going to basically cut the tops off the runners and build a secondary plenum up top?
  6. robsMarkVIII
    56
    3
    Nov 25, 2014
    United States
    Let me get the mock up made then you will understand what I am doing.
  7. beerdog
    beerdog Well-Known LVC Member
    437
    4
    Aug 29, 2010
    Buffalo Grove, IL
    I know of one person who cut one open and fully ported/polished a stock intake with good results. Then welded it back together. Paying someone to do this would have been way beyond the cost of a cobra set-up. That guy did it just to do it since he easily had the skills and equipment. Don't ask for pics or threads. He has not been on M8 forums for years. But it is doable.
  8. 98lincmk7lsc
    98lincmk7lsc Dedicated LVC Member
    3,925
    122
    May 9, 2004
    Columbia, SC
  9. ford nut
    ford nut Local nut case
    5,660
    80
    May 14, 2007
    Farmington
    • Like Like x 1
    Share This Page
