Ignition problem-cranks won't fire
big ed
Plymouth
Replaced the key switch lever, more later, now it turns over but will not fire. Going back out to try the neutral interlock cable on the top of the steering assembly. Maybe I put it back wrong? All else seems fine, cranks like crazy, steering wheel lines up, key in same old spot. Found, what I believe is the original old pin, mechanic replaced the lever the first time, on the floor, after putting everything back together. Any help appreciated. Thanks, Ed :cool:
Well... ahh....CNN reports that someone might have forgot to plug a fuse, from under the hood, back in. Oops!! Check my fuses was one suggestion & then I checked an open fuse holder. Some of us just have those days. Thanks, Ed :cool:
No problem man...glad you got it taken care of.
If you ever run into a problem like that, take a couple hours off from working on it. Cool off, and hit it again with a clear mind. You'll be amazed what you can figure out with a clear mind.
mike
