dlachance
I have a few issues I would like to address to the forum. I am constantly searching for the solution to these issues as well. The car is a 93 M8, 108k.
1.) When I start it up cold it will idle around 900 or so like normal, then when I put it in drive and give it a small amount of gas, it starts to idle funny and the rpm drops way down. If I give it a bit of gas it is fine.
2.) Sometimes after the car is warmed up, it will idle around 400rpm. If it acts normal around 600-700 and I put the A/C on, it will start to idle around 400-500. Is this normal?
3.) While driving at 20mph plus, the steering is fine. When I am turning into a a spot, I will turn the wheel as hard as I can and it will not go all the way. If I am stopped, sometimes it will barely turn with lots of force. Plenty of fluid. Also, near the front of the car, I hear a randow whine. Not like the PS pump is dry, but something else.
4.) Blow-by. Anyone know of a good product that will reduce blow-by?
Thanks for the help,
-Dylan
-Dylan
