i got my alternator fixed, but in the shop they washed the engine. the check engine started blinking and throw a code of misfire cylinder 6.
the car is slow as hell. so i thought sparks got wet or something.
symptoms:
i changed the sparks today i cleaned up everything and rearranged the coils,
but the car now is WORST the same symptoms but worst.
should i take it to a shop again? or should i try replacing the coils?
2002 v6.
symptoms:
- the car is so slow if i push the pedal it hesitates and takes too long to take off.
- the transmission is shifting at VERY HIGH revs and very hard
- the car vibrates a lot at idle like if it were going to stall
- smells like unburnt gas
- i think transmission or maybe a piston makes weird noise when i accelerate
- oil pressure light appears but goes away when i rev
2002 v6.
