Stangman
Project car a.d.d.
So tonight, it was gorgeous here in Cincy... mid 60's.... gotta love it
So I decided I needed to get to work on my Mark, I had planned to take the rear springs out and cut a small amout off to try and bring the back level with the front.
Well I got the spring out no problem. While staring at the suspension, I remembered I had brand new subframe brackets in the garage waiting for their turn to go in! (You already know where this is headed don't ya?)
So anywho, I get the two small bolts out w/ no trouble. And I already knew that the long bolt in the passenger side was spinning, so I cut a hole with a hole saw and beat the flanges down back over the encapsulatd nut, and started racheting the bolt..... but the whole bushing turns!!
The bolt backs out of the nut, and pushes the subframe away from the car, but the bolt is seized tight in the bushing.
It appears the only fix is to remove the whole rear subframe and use brute force and power tools to remove that bolt.
Unless someone has better ideas?
Also, as it sits... I may need to buy 4 long bolts and 4 bushings if I run in to this problem on the others.... anyone got any good parts for sale?
