i know every one wants there LS to be fast what about suspension ?
I back Zintkala up on this one 100%.
The car is what it is, without extensive R&D and some nice amounts of cash what we have is what we get and we will ever see.
They did a lot to this car from the start and I honestly dont think that besides the springs, bushings and swaps from sport models you are going to see anything. They did some good R&D with this cars suspension itself, think about it, why have the almost 50-50 weight ratio? How man other luxury cars have a battery in the truck to give us that near 50-50 ratio?
Springs and a proper size wheel with a matching set of tires is all you need to have the everyday fun you will see on the back roads.
I think he just asked how to make it handle better.....
So if it is not living up to expectations - make sure that the car is not worn out or messed up some how - as the stocker was a pretty good handling sedan.
If everything is fine and you want to improve it - you can look at a list of mods many of us have done for starters. click the link in my sig.
Yes...this did get a little off track. Most of my comments were directed at a certain member from NH. While I enjoy playing with my toys and wanting to make improvements as much as anybody I stand by my statement that any real high performance driving is suitable for TRACK ONLY for everyones safety.
See I went for a fully built civic I changed everything in that car motor bigger brakes full suspension that car handle like it was on rails. Then I had my) 04 g35 sport tuned 6 speed sedan. Now that car handled like a dream and that car is bigger then the Ls. I been on speed ways taking the course to learn how to better understand how to drift and handle my car on corners. So I’m well aware of my limits of my driving skill. Been thought it all drift, auto-x, off-roading. I still have my XJ with a 4.5 inch lift. 33 inch tires. So my driving skills are will up to date. Don’t get me wrong I don’t drive like an ass on the ride but when I go to PA to my favorite mount road and I let loss. there is never traffic on that road and I been driving up and down that mt for yrs and when I took the LS down the Run it would react weird.
Glad to hear that you understand what high performance driving is. This wasn't directed at you. I would look into what is wrong with your stock suspension. Most likely it just needs a little TLC. Try to get them to dial in .2 degrees negative camber and 0.00 toe when you get it aligned. Good compromise between handling and tire wear. Porobably will not ever handle as well as your tricked G35 but still not at all bad.
remember - on the 'drifting' - the LS uses an open diff - so drifting is pretty much out
Stock, yes... but you can swap the diff for an LSD pretty easily, cheaply, and quickly.
if i had the LS8 but maybe i would do it to the 6. but you guys are right i need to first change out some parts that are worn. once i get my car on the lift this weekend i'll have to check everything. i'm pretty sure if my spark pulgs that i just pulled out were still orginal i'm betting that the shocks and springs are also. and its time to change them out . 116k on them maybe. i'll start looking for shocks and spring. and order new bushing. but also i'm going to try something out and make my own strut bars if it works out i'll do a write up on it and post it up
fYI - the LS already has a strut bar that triangulates to the firewall. It's across the back of the shock towers and under the lip of the cowl covering.
Be careful about throwing bigger anti-sway bars at it.
The anti-sway bars do a lot to tune the over-steer and under-steer of the car - so make sure that is your area of focus before messing with it. Many times it takes professional level skill to really know the difference and be able to take the car to the edge where that level of tuning matters.
With me - the car is more capable than the driver....
+1 on the above advice. You can cause serious understeer if you go too stiff on the front and dangerous oversteer if you go too stiff on the rear. The front to rear balance is what counts.:)
congratulations you ARE the weakest link!
"my LS8 will out dance most any sport compact...."
Not trying to rain on anyones parade and I'm glad that you are enthusiastic about your car but PLEASE....let's get realistic here. While the LS is a very well engineered car that handles better than most in it's segment IT IS NOT A RACE CAR! With all of the standard tweaks and good rubber they can be very capable and entertaining cars to drive while still being somewhat comfortable and refined. The biggest problem is size and weight. Pure and basic physics. My car, with the mods below, stock suspension and a good alignment pulled .91G on a skid pad and has been run through it's paces on both a road course and AutoX course. While it surprised everyone with how well it ran, it's limitations were also very evident. First off the car is underpowered. Not the fault of the motor, (mine is making around 1.3 hp/ci, VERY good numbers for any NA motor) but at 3.9L it is simply too small. The stock brakes with drilled/slotted rotors, SS brake lines, good fluid and Porterfield R4-S pads will get you some very good stopping distances for a few runs. But on the track it is very easy to use them up in a hurry. 4000 lbs is alot of weight to be hauling down repeatedly. Short of a Stop Tech or Wilwood big brake kit that will cost more than your car is worth and the need for custom wheels to clear them, the LS is underbraked. Tires and suspension? Again 4000lbs is alot of weight to be hauling around. Due to the cars design the largest tire that will fit is a 245F/275R without rubbing under all out track conditions. Not enough contact patch to overcome all of that PORK. In one afternoon at RIR I destroyed a set of nittos while a friends lightened M3 with the exact same tires looked hardly worn. Short of stiffer springs there is not much to do to an LS.
Reality is a good driver in a stock Golf GTI or Civic SI can run circles around your modded LS on a road course.
Respect the car for what it is. It is a LUXURY/SPORT sedan. Refined, comfortable and entertaining to drive at 8/10's, push it to it's limits and it will bite you if you are not careful.
One final rant....Who cares? The limits on the LS, bone stock are already high enough that no where on the street can you reasonably explore them without seeing speeds that are going to get someone killed or put in jail. Trust me when I say that for 95% of you on this board, stock, this cars limits are higher than your ability to drive it. Without professional training and lot's of track time none of you really know how to drive any car to it's limits safely.
ok are you done? cause I will wait for you to finish before I tell you my Ls out handles my fully done up civic, my buddies Cobalt SS, my other buddies G35, and anyone else who has even tried her! If you think for one second that a car that doesnt weigh 4000lbs is too heavy to dance, then I think you need to do further research on cars that weigh more than 4k and are known for their handling! I'm sorry you don think these cars will do what they flat out do with ease, but except for one second that just because you cant do it doesnt mean it cant be done.
LS underpowered..... you sir havent really tried to give it any power have you? These cars respond exceptionally well to power mods! Accel coils huh? what did the get you like .5 HP? work on that car before you decide to say they are under powered!
LS is inderbraked.... I think.... no pretty know that you are talking out of your ass. Even with my 125 shot of N2O, my car on stock brakes stops faster than it goes. try using more than just the left pedal to control your speed..... you'll see your power out of the turn be more readily accessible and the braking into the turn sky rocket!!!!!!!!!!
She is too heavy..... 3750 with full tank of gas and driver, nothing removed to make her lighter. Thats not that heavy at all! 05+ mustangs are that heavy, last gen F bodies are that heavy. so these cars are as heavy and are nowhere near as well balanced, not even the new shelbys, SLP's or the Saleens.
Blowing through tires.... your running 555's! First off, you should be using the 555r2 for auto x if you want nittos.... second off, Nitto blow! And while i know its just a movie, there is a lot of truth in days of thunder when he blows through tires not driving correctly.
long story short...thank you for trying to single me out tool bag, but you need to hit the books allot more before you come here and try telling me whats up! I said it before and I'll say it again, MY LS WILL OUT DANCE MOST SPORT COMPACTS OUT THERE. And from the sounds of things, even with your fancy brakes and yellow coils, it'll walk yours too!
i seen many 4k plus cars drifting like it was nothing. the new mustange, the dodge charger, the viper. old school camaro. so dont think that a big boy car cant drift. and i didnt know that the Ls has a strut bar? so what about brakes ? just get rotors pad ss lines and bleed the system and add fresh fluid and i should see a big improvement?
it's not the weight (as long as you have the torque to go with it) is it the open diff. As stated you can upgrade it in the Gen1s easily.
No one ever said you can't drift a 4000lb car but all of the examples you just mentioned have much higher HP/Torque and lots of aftermarket support. Never really understood the whole drifting thing myself, but to each his own.
If you go with rotors that are drilled/slotted or both, SS brake lines, HP brake fluid and Porterfield R4-S pads you will see a substantial improvement in stopping distance, feel and fade resistance. I have tried the EBC and Hawk pads before and while they are good IMO the Porterfields are better. For daily street driving this is a very good brake package that will not chew up rotors or drive you nuts with squealing, chatter,grinding or excessive brake dust.
shes all stock beside the new tints all-around and 30000k xenons shes stock. just changed the plugs and all the gaskets, right control arm just came in so this weekend going to swap it in and start looking at the bushing and shocks to see how they look
Quik LS, not for nothing i love your Ls like perfect and i want your tail lights i cant find them any where. just have to keep my fingers cross untill a set comes up on ebay
although you may not have a sport model - you may have the 'sport option' - i do. If you car came with 17" rims - good chance you may be sport underneath.
I have upgraded shocks, intrax spings, howe spring rubbers, rotors, pads, SS lines, fluids, tires - even thing like seat belts (hold you firmer in place) and pedal covers (if you know how to trail brake) can all help in handling. My cross weight is nearly perfect.
depends on how fast you are racing - but things like spoilers, and dams can help turn as well.
I guess the real question is - what don't you like about the handling? The LS is no slouch.
+1 mine is not a sport but had the sport shocks, and sway bar... all the parts that will improve handling (minus the selectshift).
i have eibachs and euro shocks and it does great for a 2 ton vehicle (feels 800 lbs lighter than it is)
lower profile tires will surely help, with stiff sidewalls like the bfg g-force's. go with a lightweight wheel thats as wide as will fit, and small in diameter as you can fit/stomach. you could go with an agressive alignment at the cost of tire wear. a little extra negative camber. tracking or bump steer could result as well as wheels hopping on uneven pavement while cornering and actually hurt the handling. hope your roads are smooth.
remove spare tire and jack if your feeling lucky. a lightweight battery perhaps? oh and the driver could always lose some weight! any more than that and you'll lose the point of having a lincoln.
just add more power and you'll have the time to take the corners slower! :)
A good and reasonably priced option for you is to find a set of Factory 17X7.5" rims. They have a 60mm offset which is perfect if you plan on lowering your car and they are extremely light compared to most aftermarket rims. 245/45/17's fit this rim very well and gives you a huge range of options for tires. Good prices too because of the large demand for this size. I think Quik is running Goodyear Eagle F1's, other good choices for a daily driver would be Michelin PS2's, the new Dunlop Star Spec, Bridgestone RE050A's. Our cars are heavy so try and avoid tires with softer sidewalls. especially considering you live in NY. I just moved away from there in August for the second time. Worst roads in the country. Ripped the sidewall out of two rear tires and I'm very careful about hitting potholes and such. Replace any worn components, upgrade to sport sway bars and shocks if you do not already have them, poly bushings from energy suspension, Quik, myself or a few others around here can help you out with alignment specs and you will have a very decent handling, braking and comfortable ride.
thanks for the help. now i feel like an ass when i had the chance to get the sport wheels for 50 bucks extra from these this guy that i got my parts from in PA. i just didnt have room in my brother Gx470 for them =(
Factory 17x7.5 is to narrow to be anything beneficial IMO.
Even at the price for those factory 17s you can find a nice 17x8.5 with a good offset and not worry after lowering. Looking at my stock wheels on my car for the winter there is a huge difference. They sit way to far back into the wheel well.
i was looking at this company rota that make JDM replica wheels and i want to order a set but that when i foound out the LS isnt a 5x114 =( and i dont know if they would make wheels to fit the ls. i should call them up and see if they can make a set for the lincoln. a nice set of 16's that are super wide
Dry weather highway off ramps especially ones that go 3/4 of a circle are a good place to check out how well a car handles without getting into any trouble.(for the experienced driver)
The LS is pretty good but it still doesn't compare to my live axle 97 LT1 Camaro which despite being close in weight to the LS handles like it's on rails mostly due to it's lower center of gravity and wide track stance.
maybe for out of the turn acceleration, but that live axle seems like it would hurt traction while cornering. i think the cars actually do compare on cornering, which is a compliment to the LS, but the f-body still takes it. slalom may show more of a difference.
im familiar with my brother's 93 formula thats lowered with much wider tires.
Sitting between the wheels and tires instead of on top of them makes the biggest handling difference.
