I Just De-carbonized my engine using water
jtmforever
Alexandria
I've been looking for ways to decarbonized my engine other other than using seafoam. I've found out that water is a great alternative. I sprayed the mist water through the brakebooster hose. I made sure that my rpms were above 1500 rpm. The results are great! Smoother idle and better accceleration. Haven't check fuel milege yet.
um.....yeah....
I have used this method, and it does work... The steam helps break loose carbon and it does not hurt your catalytic converters. A lot of what seafoam does is a smoke show, a lot of that smoke is just the seafoam burning. You should see how clean the inside of a Diesel engine gets when the EGR cooler blows. Yes, too much water is bad, but a little bit that the engine can handle does wonders for cleaning it out. The important part is the mist, if you just pipe a vacuum hose to water, you'll probably F something up.
We used to do this back in the olden days of carburetors. Every so often just trickle a little water down the carb to break loose the carbon buildup on the tops of the pistons and inside combustion chambers. Works wonders. I remember seeing nothing but nasty black water dripping out the tailpipes:D I haven't done it to either of my Marks, but it's not a horrible idea.
A little history on water injection, a little long but a good read if you're a WWII aircraft fan like me.
War emergency power
From Wikipedia, the free encyclopedia
War Emergency Power (WEP) is an American term for the throttle setting on some World War II military aircraft engines. For use in emergency situations, it produced more than 100% of the engine's normal rated power for a limited amount of time, often about five minutes. [1][2] Similar systems used by non-US forces are now often referred to as WEP as well, although they may not have been at the time.
1 WEP in WWII aircraft 2 Modern times 3 WEP in surface vehicles 4 Boost systems 5 References
Maximum normal power would be limited by a mechanical stop, for instance a wire across the throttle lever slot, but a more forceful push would break the wire allowing extra power. In normal service, the P-51H Mustang was rated at 1,380 hp, but WEP would deliver up to 2,218 hp. [3] In the P-51D Mustang, the model most produced and used during WWII, the WEP increased the HP from 1490 to 1720. The Vought F4U Corsair, not originally equipped for WEP, later boasted a power increase of up to 410 hp (17%) when WEP was engaged. [2] Several methods were used to boost engine power by manufacturers, including water injection and methanol-water injection. Some earlier engines simply allowed the throttle to open wider than normal, allowing more air to flow through the intake. All WEP methods result in greater-than-usual stresses on the engine, and correspond to a reduced engine lifetime. For some airplanes, such as the P-51D, use of WEP required that the engine be inspected for damage before returning to the air. [4] 5 hours use of WEP on the P51D required a complete tear down inspection. [5]
British and Commonwealth aircraft could increase power by increasing the supercharger boost pressure.. [6] This modification was common by the Summer of 1940, with the widespread availability of 100 octane fuel. Raising supercharger boost pressure from 6lb to 12lb increased the Merlin III engine rating to 1310hp, an increase of over 250hp. Pilots had to log the use of emergency boost and were advised not to use it for more than 5 minutes continuously. The German MW50 system methanol-water injection system required additional piping, as well as a storage tank, increasing the aircraft's overall weight. [7] Like other boost techniques, MW50 was restricted by capacity and engine temperatures and could only be used for a limited time. The GM 1 nitrous oxide injection system, also used by the Luftwaffe, provided extreme power benefits of 25 to 30 percent but required cooling on the ground and added significant weight. [7] One of the few German aircraft that could be equipped with both systems, the late war Focke-Wulf Ta 152H high-altitude fighter, could attain a velocity of some 756 km/h (470 mph) with both systems used together, reportedly as Kurt Tank once did in using both boost systems simultaneously when he was flying a Junkers Jumo 213E-powered Ta 152H prototype fitted with both MW 50 and GM-1, to escape a flight of P-51D Mustangs in April 1945.
Interesting! Never thought of that.
I've heard of this but never tried it. Glad it worked for you. I've also heard of spraying windshield washer fluid into the throttle bottle for extra power but I haven't see anybody do it.
-20° washer fluid is a decent mix for methanol injection. It is more common on forced induction applications.
I just saved a bunch of money on child support by switching to condoms.
roflmbo!
As to water cleaning an engine, been done for 50+ years. Works great. My neighbor has a 1969 Boss 429 Mustang. He has trouble finding good hi-test fuel for it that doesn't ping; he added a "water injection system" (which consists of a water bottle with a small hose running to the top of the air cleaner) that solved all his pinging issues!
roflmbo!
I did that on my '69 Cougar a couple of decades ago:) Unfortunately, I used too big a hose and almost caused some severe damage to my engine. Ended up having to pull out the spark plugs and spin the engine to blow the water out of the cylinders:eek: After that, just a little trickle of water down the carb to bust up the carbon is all I ever did.
Edit: The only thing I wonder about with the water method is clogging up the cats. On older cars without cats it's not that big an issue. But if a few big carbon chunks make it to the cats it could cause problems. Of course the engine would have to be pretty gunked up for a chunk that big to be an issue anyway.
