yeah i saw my degas bottle and it has small cracks in the back, doesnt seem like its leaking from there but i guess because it didnt lose all the coolant. so could those small cracks be causing the leak?
oooh i really thought it was the chihuahua.
thanks. i've been readint that those 2 part epoxy will fix it because the cracks are really small. thanks again
every PSI the cooling system runs increases the boiling point of the coolant by 3 degrees - so the cracks are not just causing an annoying leak but lowering your cooling system's boiling point and cause the a loss of coolant out the overflow when it prematurely boils....
Just to add...
Water carries heat away from the engine quite well, but steam does not.
every psi the cooling system runs increases the boiling point of the coolant by 3 degrees - so the cracks are not just causing an annoying leak but lowering your cooling system's boiling point and cause the a loss of coolant out the overflow when it prematurely boils....
what does it use to carry this heat....like a wheel barrow or sunthin...forklift maybe?
