How far can this car go?
Lincoln LS
  1. tireman
    tireman Dedicated LVC Member
    1,243
    39
    May 15, 2005
    atlanta
    I'm at 212K miles on my 01V6 and still running strong. Replaced tranny at 75k, original engine.
    • Like Like x 1
    • 04_Sport_LS
      04_Sport_LS Dedicated LVC Member
      3,224
      363
      Jun 12, 2012
      Somewhere around Lake Erie
      For as long as you're willing to put money into it... or the body holds out.
      There's a member on here somewhere... that said he had 300k on theirs. Don't know if that was Km's or miles. Next closest is 260k miles iirc.
      Don't remember which engine either had.
      • Agree Agree x 1
      • AmsterDutch
        AmsterDutch Dedicated LVC Member
        1,854
        311
        Jul 9, 2017
        Midwest
        Just hit 216,000 on my 2006 all original engine and transmission ...Midwest car
        • Like Like x 1
        • rgorke
          rgorke Well-Known LVC Member
          462
          65
          Aug 5, 2017
          Camarillo, CA
          ‘04 V8 245k
          • Like Like x 1
          • HyeLifeLS
            HyeLifeLS Dedicated LVC Member
            5,150
            24
            Aug 23, 2005
            Long Beach
            I am on 308000miles, 01 V6 sport auto.
            Trannies are the weak point, i am on my 4th (?) one, but again i just switch another used one in there when they go bad, knock on wood this last one has been the best one yet, better than the original one.
            Engine is untouched other than tune ups, some seals and gaskets, diff original, steering and suspension is new up front OEM, rear only the tie rods are new, new hub bearings, PS pump new oem, few high pressure lines are new, original fuel pump, couple of window regulators. 5th or 6th degas bottles, 3rd radiator I think and some other things.
            Runs fantastic.
            • Like Like x 1
            • RollinLS
              RollinLS Moderator Staff Member
              4,774
              150
              Jul 4, 2005
              TBA
              I am at 245,000 with 2003 v8. Had the tranny rebuilt at 240,000. Runs like new. Strong. Reliable. No issues.
              • Like Like x 3
              • milehighmikey
                milehighmikey Dedicated LVC Member
                768
                47
                Apr 2, 2007
                Nashua
                Sitting at 315K on my 00 V6 manual, still loving the ride, quiet and performance. It still corners faster than my 07 wrx with sway bar upgrades. I just get worried in the summer heat about losing the hydraulic cooling fan solenoid and cooking in traffic, so I am avoiding its use when it gets into the 90s F outside.
              • heyjewel
                heyjewel Well-Known LVC Member
                472
                39
                Oct 5, 2015
                auburn
                Do you do the tranny swap work yourself?
              • DemonicSushi
                DemonicSushi LVC Member
                14
                Jun 13, 2019
                Missouri 417
                Ayyye midwest same here mines 198000 original engine some fixed parts suspension is in a rebuild right now but this car was ran to hell before me XD
                • Like Like x 1
                • HyeLifeLS
                  5,150
                  24
                  Aug 23, 2005
                  Long Beach
                  Yes, takes me about 6 hrs to swap it. It’s not bad at all.
                • HyeLifeLS
                  5,150
                  24
                  Aug 23, 2005
                  Long Beach
                  Nice!
                  Oh yea you gotta change the solenoid, mine went bad right after someone rearended me, Temps were find if the car was moving, but when in traffice with 90 plus weather the temps would crip up. Takes about 15 min to replace it on a V6, mine had a leak anyway, no problems since then. Definitely change it.
                • milehighmikey
                  768
                  47
                  Apr 2, 2007
                  Nashua
                  Oh I just changed it 2 years ago in July, it went bad on about the hottest day of the summer, and my first one also went bad on about the hottest day that summer (2010). So the first one lasted 10 years, then the second one died in 7 years, so now I don't trust them and I just avoid driving it on the really hot days, since my other car uses electric fans. It is working now, I just know that if it dies on the road, it's way too stressful to try any workarounds between that time and arriving back at home. So I leave it parked when its in the 90s.
                • tireman
                  1,243
                  39
                  May 15, 2005
                  atlanta
                  As far as the hydra cooling fan, i replaced 4 pumps and 1 motor, then i found the secret,,,,every spring i now use a pump to withdraw all the fluid from the pump reservoir, and install new mercon V. never a problem since.
                  • Like Like x 1
                  Share This Page
