How do I get the keyless entry for keypad ?
gen2 cars are on th keyless modual in the drivers door, not sure about gen1 cars
i got lucky on mine and found the actual card that comes with the car with the number on it in the glove box but ive all over my car and havent seen a number anywhere else
I also have the sticker on the inside of the right trunk hinge. If its not there, or behind that panel on the side of the air ride switch, check the keyless module itself? Or did you already look there?
its either on the hinge, on the keyless entry module which is a yellowish colored box next to the air ride switch, or its on a card inside your owners manual in the glovebox if you have it.
