Long_Island_LS
ok so... i ordered 2 HID kits from DDMTUNING.COM [which are APEXCONE kits]... lifetime warranty on the bulbs & the balasts... 35w 5000k... plug n play...blah blah blah.
First i installed the lowbeams... they worked the first time i hit the switch and they work 100% all the time everytime - bright as hell too.
OK, so foglight time... install the passenger side kit first [leaving the halogen bulb plugged in on the drivers side]..hit the switch, blow a fuse... ...change the whole assembly i tried on the passenger side over to the drivers side foglight - hit the switch [with the halogen bulb plugged in on the passengers side], the kit on the drivers side fires up and works 100%. So, i try again on the passenger side with the same assembly that just worked fine on the drivers side. Hit the switch, blow a fuse....
... at this point i change the foglight relay in the power distribution box under the hood... try the kit again on the drivers side...and it still works everytime...try the kit on the passenger side and now i dont blow a fuse this time, but the bulb dose not ignite [turn on]....
...i am completely at a loss.... WTF??? :Bang ...anybody with any help would be much appreciated....thanks
