Help
Dougmcmullen
2001 lincoln ls v8 have to replace water pump looking for location of radiator drain. Thanks
It's at the bottom of the right side (right if you were sitting in the driver's seat), white knob.
Do note that there is a very specific fill and bleed procedure that you must follow to the letter. Also note that there are several plastic parts that will need to be replaced.
How to Drain the Lincoln LS Cooling System
Rough idea on plastic parts for replacing
It's safe to say ....ALL plastic parts ...switch the T-stat housing with Jaguar S-type aluminum Thermostat housing ...Amazon sells them also I would replace the degas reservoir since you're in there ...FWIW ...Winter is coming
