help with fuel filter removal
Do you have to remove the right front wheel and is it behind that aft shield?
Not a problem, good luck. As soon as i get the tool ima do mine aswell,
If it just pulled off then the spring retainer is either missing or no good (stretched), you have the wrong filter or it's installed wrong. If it pops off while your driving you'll have high pressure fuel spraying everywhere!
it was a struggle, but once you have it at a bit i promise you will just slip out no probelm. mine got bent a bit.
