ncsuengin9
I need some help.
I am attempting to change out the back tail light on my 2003 LS, and what should be at the most a 15-20 min like everything I try to do on this car has turned into a 2 hour ordeal because the bolt that you have to reach through the hole in the sheet metal is on a stud that is either stripped/cross threaded/damage.
I was able to get the bolt loose but now it just sits there and spins on the stud...........
Anyone out there have any ideas????????
