Help Me Please Someone!!!! Fire underneath
That or burned out the control wire to it or blew a fuse or two.
The control wiring would be in the front harness you spoke of, would it not? And true, fuses should be checked before pulling the starter as a fire would cause a short, which should blow the fuses.
Update! I got it running after changing the starter harness and starter fuse she fired right up. Thanks you guys
"Here's what happen i was cut off in the snow and I was and ran into about 6inches of snow. Upon trying to rock the car back and forth from reverse to drive something when terrible wrong. All i know is the car lost all power and shut off lights engine and everything. I jumped out and notice I had a small fire coming from the passenger side of the bottom of the motor. I was scared as F*** called 911 to put the fire out and the fire was already gone. After about 10 minutes of the car sitting it regained electrical power lights and everything besept it attempting to crank or click noise. Now a few months ago I had the starter replaced from smelling a burning wire do you think I blew the starter again? Please help me please car is stuck on the road side."
LOL! this must've been a joke
:D:D:D See how easy an LS is to work on? The OP says he's not 'mechanically inclined' but with a little of Joe's expert coaching the job gets done! WOOT!! WOOT!!:D:D:D
KS
