Help Check Engine Code
APOLLO24
BROOKLYN
Car is running normal :steering but had a check engine code come up. Went to autozone and the guy read the code as P0153 slow response Bank 2 sensor 1 CKT please help cause I can't find these codes anywhere on this site. thanx
HO2S Slow Response Bank 2 Sensor 1
Heated - O2 sensor - pre-cat O2 sensor - not sure if it's the driver or passenger side (driver I believe).
Sounds like it's taking too long to warn up - or adjust to the changing A/F ratio.
You can get a replacement from AutoZone.
+1
But I would step up and buy a Motorcraft sensor. You just don't know what you will get from Autozone. You can probably shop around...and even look here...and get a good price for a Motorcraft.
