dnsherrill
-several weeks ago I added two driving lights behind the grill, the relay for these is fed by the batt+ and the switch for these is fed by the hi beam line/hot on the pass side (so they come on/off w/ high beams)
-Last weekend I spliced the two wires in the MF sw. (R/BK, R/Y; 13,15?) to keep the lo's energized when the brights are turned on; in prep for HID mod.
-everything was fine,as per plan
-recently noticed one of the two behind-grill lights were out; in trouble shooting (with lights turned on) I f'd up... I arked the feed/line to the light in question against the + terminal on the dead driving light
- now the problem; with just lows on, all are on (except RH fog lamp) and none of the lights have full power
-with lo's and hi's on, only the RH lights are energized but they have full brightness
is what it looks like with just low beams on
is what it looks like with the high beams (and lo beams per MF sw. splice) on
- at this point the add-on lights are out of the circuit-straight off the batt+;
-all the fuses in the LH door panel are good as the one under the hood in the PWR DIST BOX- don't know about the relays in PDB
- I removed batt.- cable, waited, then put it back, to reset- no change
-I'm also gettin a 'check ext lamp' msg in the central dash LED display board
WTF did I do?????
(fried MF switch?)
WTF did I do?????
(fried MF switch?)
