head light and rim questions
Sleeper
Sodus Point
looking at getting some HIDs from DDM. Just wondering if the 35w would be bright enough for my lows as I am going to be getting them for my lows and fogs and would like them to match as close as possible.
and now for the rim question(please understand I know almost nothing about rim fitment)
Found a set of rims I like, only problem is the center bore is 63.6mm and I read somewhere on here that the hubs on the ls are 63.34mm. Will this .26mm cause the rim to 'wobble', is it an issue? will i need spacers? do they make them this small?
I have seen these rims on 3 other cars either on here or car domain, yet none of this info can be found with the pics ;(
I just dont want my wheels coming of while going down the road.
yes the 35 watt are plenty bright, however you will probably have a lot of glare from the fogs since they dont have the little shield to block the light coming directly from the bulb to oncoming drivers eyes, be prepared to be flashed from time to time.
Believe it or not, .1mm will make a difference. I have MB wheels that need a 73.1mm O.D. hub-centric ring but I have a 73mm O.D. on there. I have the correct 63.36 I.D. ring so I get a very intermittent, slight wobble. I can live with it as, IMHO, getting the correct I.D. is more important.
