Head gasket?!?! Ugh!!!!
Smoke and Mirrors
Jacksonville
Well,after 228,000 miles i think im having my first major issue with my 96 mark. On the way to work a couple of days ago it ran alittle warm...up near the top of the normal range. Turned out the side tank on the radiator broke open and had a matchbox size hole by the outlet. Well i replaced the radiator,topped it off and drove it. At first everything was normal....then it got hot all of a sudden,then went back to normal,and the message center said low coolant. No...the sensor wasn't stuck,and there was no sign of a leak anywhere for that much coolant to be lost. Its also giving a code for a miss in the number 2 cyl. No white smoke out of the pipes,but it does run sluggish(slip of the timing??) So now im thinking head gasket seaping out. I'd gladly take some input on this as well as input on any complications i need to look for if i need to change this. I don't have a rack to put it on but i do have a brand new craftsman compressor and air tools, and a floorjack. is it do-able in the drive way,or do i wanna take it somewhere. And had anyone tackled this or had to pay for it. Is timing the cams again the tricky part? I'll glady take all the advice anyone has to offer. I love the car and i don't wanna get rid of it.
Sounds like you didnt properly burp the system.
Thanks guys! You know because i was so freaked when all of this happened,and thought i'd done major damage...i did forget to get the air out of the system. I did find out why i had the misfire...The sparkplug wire was arching off of the head. Funny how i just put those wires on with new plugs about a year ago today. Those wires suck...i got them at AUTOZONE,lol. Now,today i went to the you pull it and found a 95 mark that had just been brought into the yard. It only had 73,000 miles on it. I got the whole set of MOTORCRAFT wires,which seem to be made better than the ones i had on my car and four injectors for...$25!!! Thats right! Im goin back tomorrow to get the hard to find cup holder(with the cover),and the grill! If anyone need anything off of that car that isn't a major job to pull...let me know. It's even still got the tires on it! And yes i shut the hood to perserve it,lol. Anyway guys,thanks alot for the simple info that i overlooked
