KC96LSC
I wrote about this a few months ago and I'm still having issues. Here is what has been happening. This summer these things all started to happen. It wouldn't hold the temp. If I turned on the A/C the car would gradually start to heat up (the fan is running), I would turn the A/C of before it went to high. Along with that, My A/C would only blow cold when it was set at the 60 setting. When I would move it to 65 it would blow hot. I replace the thermostat and radiator. The water pump isn't leaking and I don't think that's the problem. As a few of you know, I was down (health) for a while. Now the weather is a little colder the temp seams to not want to heat up as quickly as it normally would. When I'm on the high and the R's are up, it runs right around normal temp.
The last time I asked about it, someone mentioned the VCRM. fortunately I found a 96' VCRM at the yard and have that in hand. I didn't want to put it in before I asked you all one more time what thoughts you might have.
I'm not sure this is related but, back when all of this started, I had pulled out my amps out of the trunk for a few days while I had some paint touched up. When I put the amps back in, I started getting a lot of engine noise. Not only the alt. noise, but I get a load hum when the fan kicks in and when the air ride comes on.
Sorry about the novel here, but any idea's would be greatly appreciated.
Greg
Greg
