Psychostang
With a wreck and solid bushings, the alignment may be fun!
More better Bill!
Change the crossover tube to 03/04 style, custom make thermostat bypass hose, remove chitty home-made tensioner that was on a shaft 1/8" too small, add back tensioner bracket and new style pulley, align the alt and tensioner properly to eliminate belt squeel, properly hook up IAC, remove worthless big oval throttle body and replace hacked upper plenum, give the crankcase some vac again and add Steeda oil seperator, add aluminum expansion tank, relocate intercooler res tank to proper position, relocate knock senors, fix throttle cable throw..... I think that was about it.What all had to be done under the hood Bill?
Nope, he has a new Goodyear 6 rib that works perfect for now and he didnt want to buy a new 8 rib. He will inthe future I believe.Did you put a proper 8 rib belt on it?
He likes my little mod and says the throttle is so much more controllable that the car is much nicer to drive....throttle cable....![]()
