got in low speed accident now have some DTCs
Lincoln LS
  1. MysticMac
    MysticMac Well-Known LVC Member
    407
    41
    Aug 18, 2015
    Vancouver British Columbia
    Got a very light bump from behind and bumped the guy in front of me. Bumper has a crack but no airbag deployed and the actual metal bumper has a tiny dent and the styrofoam bumper cover insert broke in half and fell out on the highway. I ran forscan and now i have some codes lol.... I know i have some misfires but a leaky (new) fel pro gasket kit (i will order another one because i must of pinched it somewhere) Insurance cant look at my car for another two weeks so i am wondering how bad this crash sensor code is as well as the purge valve code.
    I got a crash sensor code B1318
    code P0443 Purge Valve code
    Code U1262 Data link fault
    Code P0460 invalid fuel tank level mesage from instrument cluster
    code - P0113 IA sensor circuit high input
    code p0174 system too lean ( found more oil on my drive side plug wells, and can smell gas on the plugs. (will order 2 more coils and three plugs because I have a brand newmotor craft coil un opened)
    Code B1318 battery low voltage ( weird because I have a brand new battery and havent died)
  2. MysticMac
    407
    41
    Aug 18, 2015
    my air bag light is not illuminated when driving.
  3. MysticMac
    407
    41
    Aug 18, 2015
    also b1994 side air bag circuit open front driver side
  4. joegr
    joegr Dedicated LVC Member
    20,292
    1,616
    Dec 10, 2005
    Gulfport
    B1318 low battery voltage - no biggie
    P0443 purge valve circuit - emissions - not urgent
    U1262 only a problem if constant
    P0460 problem with the "A" fuel level sender
    P0113 bad IAT - bad MAF or wiring - I'd make this a priority, could be the cause of the lean mixture and some misfiring
    You should have the SRS light on due to the B1994
  5. MysticMac
    407
    41
    Aug 18, 2015
    I will unbolt the MAF in the morning and check it out. I didnt see any pinched wires or anything so maybe its just bad.
    So regards to the fuel sender code, what would I do to fix that?
    and the crash sensor code would just be erased or do i need to replace the crash sensors now?
  6. MysticMac
    407
    41
    Aug 18, 2015
    and thank you!
    Yes I see the SRS light. How do I fix this? lol
  7. joegr
    20,292
    1,616
    Dec 10, 2005
    Gulfport
    It's probably a break in the wiring somewhere between the RCM and the airbag in the driver's seat. On gen I, it's almost always at the connector under the seat, but gen II doesn't seem to have that problem.
  8. MysticMac
    407
    41
    Aug 18, 2015
    I was mistaken there was no SRS light.
    I was cleaning under my seat and possibly could of crimped a wire.
  9. MysticMac
    407
    41
    Aug 18, 2015
    Im going to check all wiring from rear control module all the way up to the seat
  10. joegr
    20,292
    1,616
    Dec 10, 2005
    Gulfport
    REM is the Rear Electronics Module. It has nothing to do with the SRS.
    RCM is the Restraints Control Module. It's under the floor console.
    • Like Like x 1
    • MysticMac
      407
      41
      Aug 18, 2015
      i have no idea whede the floor console is? im assuming under the seat? lol
    • joegr
      20,292
      1,616
      Dec 10, 2005
      Gulfport
      That thing between the two front seats that has the gear shift lever, the parking brake, AdvanceTrac/Traction switch, cup holders, storage compartment, rear AC vents, and power port.
    • MysticMac
      407
      41
      Aug 18, 2015
      ohhh the center console lol... thats what I call it. Yeah Ill remove it and see wahts up
    Share This Page
