slowmkviii
Keviiin you will need a tune.
So I figure that must be something controlled electronically through either RPM or throttle position.
I'm sick of the SLOW shifts on my 98' and it's past it's trans fluid change time. So while I have the pan down I'm deciding on what way I'm going?
you dont have a programmer by now? alot of people are down on the sniper, ive got it, probobly the best feature on it is the means to completely adjust allshift points and firmness. mine barks second with the stock rear. there are alot of variables that in tuning are best lft to people who understand what they are doing like a/f ratios and timing. but it also has a real time analysis screen to read all that while the car is running with laptop. im still gonna do the jmod because of the longeveity it adds to tranny with allowing extra fluid to travel through, but with a tune the two together are incredible.
Kevin, I would hit up BOC and have a chip burned. Best 325 bones you could spend on your car. Or you could buy an early 93 computer.
dumb question..who or what is BOC? Still kinda new here i don't think i've seen anyone by that username.
blue oval chip
I actually contemplated removing the computer from a 93..I've come across quite a few at the junk yard. Is it a straight up swap for the 94/95? or does anything else have to be done?
http://www.blueovalchips.com/
Lonnie is also a member/vendor over at LOD.
i have a blue oval chip and its great. he is familiar with the JMOD and everything cuz he has a mark.
should be a straight swap. easy.
some people say traction control / non traction control makes a difference, but i haven't seen any proof of that.
If you can find it the W3Z2 computer is the one to get. If you can't find one I have one and I live close. Might deliver it for a little compensation.
