DaleGrib
In the last two years, I have had to recharge my a/c system about one year apart as it's got a very slow leak somewhere. (I have used the stuff that is supposed to help with leaks but it didn't seem to make much difference as it lasted maybe a month longer this time around.) On these cars what would be the common areas that they tend to leak from? I know the only way to find out where it is leaking is by using a dye or sniff tester or paying someone to find it. Gonna try to grab some Dye when I refill the system so I might see where it is leaking from. But was just wanting to have an idea if possible where the trouble points tend to be. It's not something I would want to go crazy with breaking the bank to find such a small issue but if it's something within reason then I would try to tackle it before the summer gets here.
