kaha
Well, I figured out the cause of that ABS light staying on. I noticed I hadn't heard the air ride compressor running since then either. I noticed THAT after I went out to the car after work to drive home and noticed the left rear corner was slammed, and firing it up didn't help - no compressor.
Checked my fuse chart, and noticed fuse 10 protects these circuits: Multi-function switch, air-bag system, ABS, air suspension
, Manual Lever Position Switch (whatever the hell that is), daytime running lamps, flasher, and back-up lights.
It's also supposed to be a 15 amp according to the chart, but the 20 amp that was in there had been in there a long time. Swapped it out (with another 20), fired it up, JOY! Compressor kicked right on. No more La Bamba!
So today the ABS light kicks back on. Fuse 10 is blown again.
Any clues as to what to check first, or areas to suspect?
