col batitong
Hello everyone, This is how I install my angel eyes on my Gen 1 lights. as stated in the other thread,
1. I did the oven trick on my gray sealant headlight. 8 minutes, 250 degrees Fahrenheit. The black sealant (PITA) I cut it using a box type cutter blade. I ran the blade many many many times around the edges of the light, until I was able to pry the headlight. I separated the clear lens, black bezel, chrome reflector and the back housing.
2. I attached the Angel eyes to the black bezel using a clear silicone. I tried many times to find a different ways to attached the angel eyes to the chrome reflector, no luck. I think you can only attached the angel eyes on GEN1 lights to the Black bezel. I used a duct tape to temporarily hold the angel eyes in place while I put the silicone behind it.
3. At this time I replaced the yellow corner lens with the Alex7's clear corner lens, very nice
4. I ran the angel eyes wire thru the vent hole of the headlight.
5. I Hooked up the angel eyes power inside the vehicle, due to I want a separate switch to control it.
6. I ran and fish the wire to the passenger side firewall. I removed the plastic cover at the bottom of the windshield by the AC filter and you will see there's a sticky pad that is covering the hole to the firewall. I inserted the wires using a general purpose galvanized wire. insert the wires one by one. the hole is kinda tight. I used a 16AWG wires, Red positive, black ground and white for the trigger switch. The wires came out under the passenger dash. remove the glove compartment door and you will see the wires that you inserted from the firewall.
7. I pulled the wires then ran it to the rear cigarette lighter outlet, where the rear AC vent is. no screws to remove in the AC vent, just pull it and it will come off. Tap the red and black wires using a soldering iron. Take note. I tap the power there due to it being live all the time. I then fished again the wires from the passenger side dash to the driver side dash where my switch will be placed.
Attached pics are also the switch button and Butyl rubber I used to re-seal the headlights.
