I thought so too when I saw the title. Then saw it was made by 02V8Sport.
No 8.8" unit is going to be a direct bolt in.
Only one guy has the 8.8 rear end with t lock and 4.10's. It takes a custom front brace and a custom driveshaft for it to work. I may go that route if I can't find some custom gears.
As far as a limited slip diff, I have an 8.8" 28 spline carrier from an 05 mustang gt installed in the stock 8.0" housing. Bought it for 75 bucks IIRC. it fits perfectly, but you have to reuse your stock ring gear and pinion. You will probably also have to reshim to allow proper backlash.
If you haven't done this before, just buy the parts, and have a shop do it. May cost you 100-150 extra for their labor. But that's cheap peace of mind.
