02V8Sport
$1100 shipped to your door plus a $500 core charge until I get a fully functional unit back from you. Includes complete carrier with new LSD differential, new bearings and all new seals. Pic attached.
Is that a swap your own ring gear out set-up?
That doesn't look like the T-Loc in the pic. Is that the Gen1 carrier in the Gen2 case....so they just went to a 1 cap design but the bearing on that side is the same?
I know the bolt pattern of the ring is the same as the 8.8. But what about the meshing of the gears.
How come you are swapping back to the gen2?
I really do not want to rain on anyones parade but did you do a full axle fitment test after the swap of the 8.8 LSD into the Gen2 carrier? The only reason I ask that is because of the way the Gen2 differential mounts into the Gen2 case may have determined spider gear/splined area throat depth. By the looks of it the axles might stick out about 1" further when using the 8.8" differential in the 8.0" Gen2 carrier when compared to stock Gen2 8.0" in Gen2 carrier.
Hopefully you verified this because if the axle does stick out too far while using the 8.8" LSD in the Gen2 carrier then it will be a no go. It would be nice if this were not the case but it is better to be safe than sorry.
You are right ILLS. There was a revision made this morning to the design. We are still able to LSD the unit.
Is this setup as quiet as stock.
Is there any whine which can be typical with custom rear end setups?
Thanks.
What exact revision was made?
Dont know, the carrier was assembled before I had the chance to see what was inside.
The stock axles were test fit and all is well. I will put this 03 carrier back into my car in a week. And what misunderstanding are you referring to?
The issue was addressed very early on during test fitment.
