front windows sticking
Over2tonsofFun
Laramie
My 89 Town car has a problem the front windows stick when going down. mostly the driver but the pass does it too.
The vent windows go down great but when it comes to the main window it gets stuck about 1/3 the way down. I have to force it down the rest of the way.
Anybody have this problem and what I need to do to correct it?
Thanks
Tim
Do you know if its because of the motor, or because its actually sticking?
If its the motor, you need to replace the nylon bushings, if its getting stuck, you can take the seal out and put some lube in there; whatever kind you like
Windows Stuck
Id go with Mr Wiggles on that one because if it were to be the regulator the window would just not work, and im guessing you can still hear your motor so theres that one out of the way, so i would say some good ol fashioned lube
