Front or Rear tires wear faster?
Quinton
Kansas
I noticed on our "new" LS that the rear tires are in better shape then the fronts. I doubt they have been rotated recently so I'm wondering if the fronts wear faster for some reason?? If you like to roast your rears don't answer please. LOL
Thanks
totally depends on the driving style -
- since the car is heavy - wearing the fronts is not abnormal as the car can push mildly in corners
- since the car is rwd most of the traction off a start is on the rear wheels - so I usually wear those out first
You might also check your alignment. Fast wear on fronts is often a symptom of the alignment being off.
I think with our cars being independent rear axle, we probably also need to spring for the 4 wheel align versus the traditional 2 wheel used on RWD. Just guessing here.
Also make sure your air pressure is right. I think the manual recommends something like 30psi( a bit low in my mind). The tires I think are rated for something like 44 psi max or so, way too high for normal use. I find that usually going near the manual recommendations or right around 32 psi usually gives best wear. I have seen some cars where following manual recommendations resulted in center(overinflation) wear. I haven't owned the LS long enough to say here so I will stick right around 30-32 for now. I usually have to almost wear out one set of tires before I know how the car likes it's tires inflated. Expensive lesson, but once that is over I usually get about 50K from my tires so in the long run it is cheap to learn what your car likes.
Also rotate regularly. I do it every oil change.
Inspect your tread periodically, sometimes you can detect a bad wear pattern adn correct it before the tire is gone.
Good Luck,
Jim Henderson
