Rayz1024
Hello all,
Just bought myself a new headache last week...got a real pretty 93 mark viii for a good price. Ive read through almost all the threads in here and ive tried everything that i found, but still nothing. Ive got a real annoying rattle sound in the front drivers side of the car. Its when i go over bumps, big or small. IVe changed the lower control arm (ball joint and bushings), and the strut rod bushing that goes through the control arm as well. Sway bar links, tie rods and upper ball joints all look good. uca bushings look good too. Ive pushed, pulled and shaken every part under there, both on the ground and on the lift...cant replicate the sound. it does have a coil conversion on it (arnott). I bought it with the conversion already installed. I checked the top of the strut to make sure, and everything looks to be seated correctly. I brought it to a shop and they couldnt find it either. So just looking for suggestions.
And also, my A/c and heat work fine, but it only blows through the defrost vents. cant get it to blow out the panel or floor.
Any help is much appreciated. thanks
