front end poly question
normohl
rattman
my front end needs a complete rebuild, i have about every clunk clatter click that you can have, i have read to buy poly stuff from SC but there is 700 bucks worth of poly stuff for the marks front end on there, i dont want to spend 700 on poly what needs do you prefer to be poly?
Call Max at Five Star Ford. Hes teh man and will treat you right. He gives discounts to members here on OEM stuff. On the right side of this page you will see his ad.
For poly in the front the only bushings that I would use poly is the sway bar end links and mounts and the steering rack bushings.
If you are getting clunks then I would get OEM strut rod bushings front and rear. Make sure for the front strut rod bushings you tell Max you want them with the sleeves in the full kit. If your bushings in the upper and lower controll arms are shot then just buy new controll arms. IDK what Max sells them for or even if he can still get them ut SCP has them for fairly cheap.
Hope it helps
