00NORCAL V8
your LS did you do it yourself? If so please rate difficulty from 1 to 10. What kit did you go with? TIA
00NORCAL V8 said:your LS did you do it yourself? If so please rate difficulty from 1 to 10. What kit did you go with? TIA
raylisiak said:About a 5, not hard, more time consuming, make sure you have help when doing the rears. Its hard to get the top bolts through the trunk area without being able to see the holes from the bottom, and on top of it, you cant hold the shock in place and reach around to put the nut on. The fronts are pretty simple, the whole arm just completely drops down. I have the Sprint springs, handles Awesome!!
00NORCAL V8 said:Where can I find those?
:I I have Eibach's too!SurfjaxLS said:Eibach
Quik LS said:I lowered about 2" all corners using the Intax Sport Lowering Springs. It vastly improved my handling.
There is no camber aligment on the LS - so depending on the amount lowered - your alignment shop will be able to get the front wheels close but the rears will be out.
I left the camber in since I auto-cross alot.
Quik LS said:relax - a 0.5 degree is nothing big - plus it helps on those corners...... I am running 1.5 degrees camber.
there are no aftermarket swaybars - but the LS has four options to choose from - v6, v6 sport, v8, v8 sport - with the v6 being larger than the v8 due to the weight of the engine. Not sure why you would want to change the sway (anti--sway) bars - it does not improve handling - more it changes the amount of over or under steer......
GrayGhost1 said:
2001LS8Sport said:Quik...anyone you know of offering arms or any other type of kit to fix the camber problem? I would think this is something that they would want to address.
Nolan,dropped74 said:Ghost how does your car ride compared to a factory suspension. I have riden in a few cars and trucks that have been lowered, but they were all pretty significant. I figure with such a small drop it might not affect it like it did in these other cars that I have riden in. Thanks
Nolan
:Beer
