Exhaust X pipe placement question
fatboyq
Chicago
ok so far I had a bone stock 98 LSC CE
I just cut the mufflers off 2 weeks ago, don't like the tone or the drone of the exhaust
next steps:
bought a X pipe from summit racing
Bought a dynomax 2 in 2 out muffler from summit
Plan
replace resonator with the 2 in and out muffler and install the x pipe right under the drivers seat area.
questions
1. should I put the x where the resonator is now?
2. Leave resonator alone and remove 3 cat and put x there or muffler there
just trying to figure out placement of the X pipe and 2 in and out muffler. I plan on running like this for a while and then if I dont like it buy some Borla or magnaflow mufflers and weld them in out back with stock tips I dont like most aftermarket tips
thanks for the ideas
cats > x-pipe > resonators > muffler(s)
to run mufflers without the resonators makes a tin like noise.... I dont like it. But its up to you. experiment a bit if you have the resources to do it yourself.
I'm going to go with 2.5" from the cats to a hedman hedders x-pipe where the 3rd cat is then to 2 summit turbo 2.5" Mufflers.
I also have 2 2.5" glasspacks in case it's too loud. These will go before the x-pipe...
If anything get rid of the 3rd cat...
i put the x pipe in place of the third cat, then 2 1/2 duals back to magnaflow magnapacks...the x pipe is a ford piece.....GT500 KR, fits in place perfect
I had magnapacks on my 99 cobra it was loud as hell even with cats. I want a mellow tone with a nice growl... would removing the 3rd cat throw a check engine light?
so you guys are saying to keep the resonator.
do this....sounds great on my 93....2.5" all the way
Did you buy that GT500 X pipe from ebay? I saw like 4 of them, I figured they were BS, who would remove a X pipe from a GT500 with low miles?
how does it sound with that X pipe and magnapacks? did you retain the resonator? any sound clips?
I knocked out the front cats and what a difference. It sound nasty now. I have stock pipes with the 3rd cat and 4" magnaflows it bad a$$ . Never would have guess it would make such a big difference. Not exactly street legal through.
there is NO resonator on a gen 2 lsc. stock you have the first set of cats then the 3rd cat then 2 mufflers out back. if i was you id loose the 3rd cat and put in a x then 2 mufflers out back
I'm really curious how my car would sound if I kept the stock cats, put an X pipe in place of the third cat and kept the stock mufflers... only one way to find out :D
Yeah thats how I started too keeping it quiet that is. If nothing else its a great start for something more.
