ForeverScrewed
Yesterday I took the Mark out for a drive and after a few minutes of in-town driving, I made it to the 2 lane highway and went to push down the throttle and the car just bogged down and died. It would start back up, but it idles like crap and when I try to rev the motor it just dies.
While idling, I heard a major hissing/vac leak sound, found that the tee that comes off the metal elbow of the throttle body and runs to the pcv and back to the gas tank. Replaced the tee and still having the same issues. Still hear the loud hissing coming from the drivers side of the throttle body area. Checked all of hose little plastic hoses coming off the sensors on the drivers side cam cover and they all check out good, brake booster line is fine. All of the vac. lines that I cna find around that area all check out fine.
I did find that there is what looks like some kind of vacuum diaphragm (I have no clue what it is) that has a little plastic vac. line coming off the top of it and a little rod coming off the bottom. the rod on the bottom was unhooked to whatever it hooks too. I have no clue what the part is and what it's purpose is.
I'm getting to my wit's end with this car and am not sure where to go to next. I am trying to locate more possible vac. lines around the TB, but have no luck finding anything. Anybody know of any or of what else I should check?
