ForeverScrewed
I have tested the TPS on a 302 before, many many times with my voltmeter, I just didn't know what the output voltage is supposed to be on the 4.6.
Same, its rhe same EEC-IV.
when checking fuel on a efi car you also need to make sure the injectors are firing. just listen for them when turning the key.
but you have something else going on major for it not to want to rev.
did you jump the eeciv connector and try for codes?
also make sure the cps is still connected. that is the culprit for my only fail to start.
There are active codes and stored codes.I am under the understanding that you can only jump the pins in the test connector for EEC-IV and pull codes if the CEL is already on....
I did not check on the injectors, I will listen for them when I go at it again tomorrow.
I am going to try and unplug the CPS and plug it back in and see what happens also.
I did a KOEO and got no codes at all, so I decided to go back to some of the basics and check for spark. Turns out I was getting no spark from the passenger side coil pack and the plugs were fouled out.
Getting 12.77 volts at the connector to both coils. Going to re-check each plug for spark now.
I FIGURED IT OUT!!!! The cats were clogged dammit. I was trying to start it and had my brother hold his hand by the exhaust, and he felt nothing coming out when I was trying to crank.... So we cut the pipe just behind the cats(we DID NOT remove or actually tamper with them) And it started right up. Blew all kinds of :q:q:q:q out, but it now runs and idles awesome. Guess it's time to get the true duals I always wanted on this beast.
Oh ok got you now. Remember if front cats are broken up that abrasive cat material gets sucked into engine and kills the rings. So watch for oil usage after fixing.
