started out thinking It was an ignition problem.changed plugs,wires ther swaped coil pack from one side to the other,same problem.when it started missing we would pull the plug wires one at a time to see witch cylinders were missing.it was always the same ones only there was plenty of spark,so that means no fuel.changed the sol.in the EGR circuit,and the pcm,still the same problem.when the engine is cold it runs fine.when it gets to the R on normal it breaks down,it has a new exaust system and the EGR pipe is welded solid.
