Electric fan controller question for Gen1 LS
00LincLS
Columbia
Wiring question for the Derale 16833 dual electric fans. This is for a 2000 V8 3.9L LS
Everything is almost complete and after a few suggestions and posts from the past I went with the Derale 16789 Dual High Amp Fan Controller.
My question is, where do you put the thread-in probe?
(I know some of them have a small slide in prob that goes into the radiator I believe but the instructions for this one aren’t clear)
Or if you did this job where did you put yours?
I searched my 2005 LS service manual (CD) and couldn't find the info. Enter the following into Google search and see if it helps:
"where is the coolant temperature sensor that operates the electric fan located on lincoln ls 3.9l"
You do realize that I’m installing an electric fan since the generator 1s originally came with the hydraulic fan system. So with that being said there is no coolant temp sensor that operates an electric fan
You do realize that I’m installing an electric fan since the gen 1s originally came with the hydraulic fan system. So with that being said there is no coolant temp sensor that operates an electric fan
