2000sport
The spring is properly seated against the upper mount, however, on all 4 corners, it is not fully seated against the LOWER mount...
I fully seated the springs when I installed them on the struts but when I went to install the struts on the car, the lower eyelet did not match up with the lower control arms/knuckles. So I had to twist the strut about 30* on each corner to get them matched up. Looking at the dimensions of the spring, and the angle at which it is coiled, this should only make a 2-3mm difference in ride height, not to mention, should still be even side-to-side.
