just come across this....
http://cgi.ebay.com/ebaymotors/Must...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Here is the part's list that would be needed when doing the swap for 99-01 cobras and 03-04 mach 1's.You need to add 99+ heads and some custom work to make it work in Mark VIII.
(6312) Crank pulley /Harmonic Balancer
(6312B) Supercharger Crank drive pulley
(8678A) Pulley w/mount Replaces stk. alt. Pulley on 99-01 Cobra’s and 03/04 Mach 1’s
(6B209B) Pulley bridge assembly for S.C.
(8678B) Idler pulley,timing cover LH side
(6D080) Timing cover
(10A313) Upper alternator bracket
(10153) Lower alternator bracket
(10346) Alternator
1U2Z-14S411-TA Electrical connector (alt. to harmness )
(6B209A) Tensioner on timing cover
(8260) Radiator hose
(8A593) Radiator hose
(8K576) Radiator hose
(8548) Water cross over pipe
(6881) Cobra oil cooler adapter
Note: Use your stock gasket from your adapter or a leak will occur
with a Cobra gasket!
(6A642) Cobra Oil cooler
(9002) Cobra fuel tank
(9H307) Cobra fuel pump
(6F066) Eaton supercharger
(9424) Lower intake
(6K775) Garrett factory intercooler
3U2Z-14S411-JUA IAT sensor connector
(9H308A) Intercooler hard lines that hug the block
(9N491A) Intercooler hard lines that come from the h/e
(9L443A) Intercooler pipe to heat Exchanger that goes from the i/c adapter to i/c res.
(9L443B) Intercooler pipe to heat Exchanger that goes from the i/c adapter to the hard lines that hug the block
(9L443C) Intercooler pipe to heat Exchanger that goes from the hard line to i/c pump
(9L443D) Intercooler pipe to heat Exchanger that goes from hard line to hard line coming from h/e
(9L443E) Intercooler pipe to heat Exchanger that goes from hard line from h/e to i/c pump
(9L443F) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e
(9L443G) Intercooler pipe to heat Exchanger that goes from hard line and connects to h/e
(8501) Ford / Bosche water pump for intercooler
(8K226) Factory heat exchanger
(8A193) Heat exchanger mounting bracket
(8C386) 2each bracket clamps for h/e
(9N491B) Lower manifold to intercooler water adapter
(9A589) Plenum
(9E926) Throttle Body
(9B659) Intake tube from maf to t/b.
(9F715) IAC valve
(9F593) Injectors
(6F089) Boost bypass actuator
(8N500) Intercooler pump bracket
(9A825) Cruise control cable
(9A758) Throttle cable
(9728) Throttle and cruise control cable mounting bracket
(12B579) MAF
(9D475) EGR valve
(9D477) EGR tube
(6C324) PCV tubing
(9F479) Sensor on the back of the S/C
(9J432) Bracket for vacuum stuff on left side of the S/C
(9H465) Vacuum stuff
(9J459) Vacuum stuff
(9J460) Vacuum stuff
(9E498) Hose's or tube cluster of connectors for the vacuum parts above
(9F670) IAC gasket
(6020) Timing cover gasket LH side
(6020) Timing cover gasket middle
(6020) Timing cover gasket RH side
(9H486) Intercooler to S.C. gasket
(9L437) Plenum to S/C gasket
(9D476) EGR gasket
I'm saving that damn list so I don't have to try and find it next time this comes up... lol
by the time you aquire all the s*it, you are better off just finding a wrecked cobra(because there is a lot of idiots who don't know how to drive a fast car) and get the drive train out of that and then you have a great base to start with![]()
HAH by the time you find a salvage, you'll be THOUSANDS of dollar over what a conversion would cost. just the wiring and computer work alone would blow the budget.
Not where I get my parts from....ha ha ha! I will never tell! Yeah, your right! You could save a good amount if you were able to do it yourselfFrom the looks of it, you speak from experience! BTW nice car!
