Eatc codes ????
Lownslowlsc
N il
did the self-test and came up with a 135 and 155..I've determained through searching that the 155 is the blower motor module dudad under the glove box.
Whats the 135?
Btw, my blend door is busted..Though doesnt indicate that through the test?
02 sensor heater circuit malfunction bank 1 /sensor 1 #135 code, this is right out of chiltons repair
what year ,this is for a eec-iv lincoln computer car and your o2 sensor is not reading might be a bad o2 sensor or the wiring
How would the o2 sensor code come through the self-test for the climate control?
that helps alot, and both codes are o2 related for a obd ll eec-v lincoln mark viii.Code #155 is 02 sensor heater circuit malfunction bank 2 sensor 1
The EATC codes are NOT OBD-II codes.
Someone with a Gen2 manual will have the codes. The Gen1 codes are 01 through 05.
Check out this LINK.
hmmmm...idk
Everything seems to operate just fine with the blower i just get the code..I thought it was the module cause they tend to get wet from water coming in through the duct that is prone to have a leaky gasket....I inspected said gasket and it appears to be sealed completly
Sorry,disregard my previous post they are worth less and how did you pull the eatc codes
